by ericmark »
Fri Jan 06, 2017 10:19 pm
You can no longer buy frosted/pearl tungsten light bulbs, so you will have to use LED light bulbs to get the effect.
Putting LED bulbs in series is not a good idea as you have no idea of internal circuit of the bulb, so have to be in parallel, even at 10W each and that is far bigger than you need you could have 280 bulbs before you hit 13A. After 200 bulbs I would be measuring as rated 10W does not mean exactly 10W could be 12W.
I would say it depends on the bulbs you can get cheap, Pound world did some GU10 bulbs at 0.58W each, since you not really interested in light output these would look fine.
But start by looking for cheap bulbs, then price bulb holder, then select cheapest pair bulb and holder.
