Cutting in a new window
peterwg
by peterwg » Sun Aug 19, 2007 4:00 pm
I have a small bathroom with no window, and plan to insert a 400mm W x 300mm H double glazed hard timber framed window. The window will be in the middle of a large exterior cavity wall. I plan to add one row of decorative bricks above the window to match the other windows.
Casual opinion is that the window can just slot in, with cavity moisture drainage protection as described on this site.
Q. I do not want to make a much larger hole to put in a lintel if I can avoid it, and if the wall WILL take it. What do you advise, Please?
john60wales
lintel
by john60wales » Sun Sep 02, 2007 5:48 pm
You really should use a lintel. Its up to you of course & I suppose it depends on how many courses of bricks/blocks are above the window - the more there are the heavier they'll be. Some walls are built with 'rat runs' - every so often a brick is placed acrross the gap between the courses. This [as well as supposedly making it difficult for rats] give the walls added strength.
Personally I'd put in a lintel & forgo the fancy stuff..
John
TheDoctor5
by TheDoctor5 » Thu Jan 22, 2009 10:19 am
It is currently Sat Nov 23, 2024 8:40 am
