Removing Laminate Flooring Advice Needed and What Tools to use
nightowly
by nightowly » Sun Jan 15, 2017 11:25 am
I'm having difficulty removing laminate flooring, What tools would I need to remove it so I could replace it with a new one.
When I try and remove section by section its jammed tight. When I try the whole floor board lifts up. The floor boards are so near the wall it's hard to break it up. I managed about 2 pieces.
Re: Removing Laminate Flooring Advice Needed and What Tools to use
by welsh brickie » Sun Jan 22, 2017 10:10 am
you can buy or hire a multi tool or small circular saw and adjust the blade so it cuts just the thickness of the laminate
It is currently Mon Dec 23, 2024 3:19 am
