Repairing Plasterboard Around Inspection Hatch for Flue
inkypinky
by inkypinky » Thu Jan 26, 2017 3:24 pm
Hi All,
We had flue inspection hatch installed in living room ceiling couple of years back (2013), the same became faulty and needed replacing, while taking out the old hatch enclosure the plasterboard paper has also come off. What is the best way to seal the plaster and then fix new hatch?
the new hatch is just placed over the gap awaiting to be glued once i am able to fix the plasterboard
picture below
many thanks
inks
Re: Repairing Plasterboard Around Inspection Hatch for Flue
by welsh brickie » Thu Jan 26, 2017 10:41 pm
to patch it you will need an angle bead to create an edge for the plaster, and patch the plaster to it,or you could use architrave to surround the area, and hide the plaster, you could use either timber or plastic
inkypinky
by inkypinky » Fri Jan 27, 2017 2:13 pm
many thanks
I am a fairly new to DIY so how will the angle bead be fixed, the hatch is at the ceiling, can you point to some products how they look like.
rgds
Inks
It is currently Sat Jan 11, 2025 8:06 pm
