Best way of Measuring Opening for new Exterior Door Frame
Post your questions and get answers on the subject of setting out
Khuz360
by Khuz360 » Fri Feb 10, 2017 4:04 pm
I'm looking to replace an exterior door frame. What would be the best way to get suitable measurements because I'm planning to order online and I don't want to make a hash of it. Also how much tolerance would there be given that I'm intending to paint the frame before it is fitted.
Re: Best way of Measuring Opening for new Exterior Door Frame
by welsh brickie » Sat Feb 11, 2017 9:11 am
use a hammer and flat screwdriver and take off a piece of the external plaster at the sill height, both sides you should be able to see the brickwork. Use a spirit level and check the frame for plumb, and see if the frame is out, allow for the tolerance.
Measure the internal plaster and check for the difference is measurement,
You may need an add on of 20mm for the hinge side of the door, as the hinges are on the frame of the new door so allow for that.
So if the door for example is 900mm wide brick to brick the door will be 870mm plus 20mm add on, allowing a 10mm tolerance
It is currently Sun Dec 22, 2024 3:11 am
