Party Wall Notification to Owner of Property or Tenant
Cathalmf
by Cathalmf » Thu Feb 23, 2017 5:13 pm
I need to issue a party wall notification with some work im doing.
I just moved in and the neighbours are renting.
Do i have to notify the tenants or do i need to find the name/address of the owner and notify them?
Re: Party Wall Notification to Owner of Property or Tenant
by stoneyboy » Fri Feb 24, 2017 7:43 am
Hi Cathalmf,
Definitely the owner but it wouldn't hurt letting the tenants know you will be working on the party wall.
Regards, stoneyboy
Cathalmf
by Cathalmf » Tue Feb 28, 2017 3:20 pm
does replacing a stairs which is against the party wall require a notification?
by stoneyboy » Thu Mar 02, 2017 9:23 pm
Hi Cathalmf,
Assuming you will not be cutting out your side of the wall to some depth to insert treads, replacing your stairs does not need a party wall agreement. You should not need to cut out the wall to fit new stairs.
Regards, stoneyboy.
