Correct Wiring for a Pair of Rotary Switches
JonDoh
by JonDoh » Tue Mar 14, 2017 11:24 am
Hi all,
I was wondering if anyone could advise on the correct way to wire up a pair of rotary switches.
Its to switch between 4 fixed speeds on a pair of 1ph centrifugal fans in my workshop, they will be placed in an enclosure and require 4 live connections each, do I just run a the main live into one "in" connection and bridge that into the other 7 or should the wire be split prior to connection, as in 8 individual wires?
240v, low amps, 4 max
Re: Correct Wiring for a Pair of Rotary Switches
by ericmark » Tue Mar 14, 2017 10:52 pm
It will depend on how the fan is internal wired, there is no one size fits all answer to this.
It is currently Fri Nov 22, 2024 9:14 am
