Fitting concealed hinges
Balfour
by Balfour » Mon Aug 20, 2007 7:52 pm
Hi, I would like to fit 31mm MDF doors to a cabinet which is made of 25mm MDF
What size concealed hinges do I need to use, will they open 110 degrees + and what size should the hinge boring bit be?
The height of the doors will be 2m10 how many hinges would I need to support this?
Thanks in advance for the help
Balfour
joust180
by joust180 » Tue Aug 21, 2007 4:27 pm
You can buy a kit for doing the hinges now,just do a search for it and you can get hinges easily to open past 110 degrees,as for how many--four will be fine at that height stick them at (this isnt critical) 125 or 150 to the centre top and bottom and then spread equally in between.
It is currently Sun Nov 24, 2024 3:53 am
