My plumber fitted a new (very nice) shower that requires a 40 amp supply onto the existing wiring which is 30 amp, after 10 minutes under the shower it will cut out as the fuse trips (and is v.hot). I like the new shower and don't want a less powerful one. It is on 6 mm cabling and is directly connected through a wlex box that has 30 amp written on it. What I want to know is if I buy a replacement fuse for this box that is rated 40 amp will it work as required.
Link deleted
Cheers Matt OC
