Decking Support Advice Needed for Deck Spanning Gap Between Boundary and Hedge
Ask questions and find answers on all your decking problems and issues
matpj
by matpj » Tue Apr 04, 2017 12:21 pm
Hi folks,
I'm about to start a project to put a deck down to span an area between the edge of our patio and the hedge boundary of our garden.
The distance between is approx 1.3m
The ground slopes away from the patio and at its furthest point is probably a max of 40cm drop
I was thinking of having the decking rest on the patio with an overlap
I would then sink some posts by the hedge to attach the joists to.
Would this be the right way to go, or is it a bad idea to have the decking resting on the patio surface with only one end bolted to posts?
and are there any things I need to be wary of. I am planning on using postcrete and dig 700mm holes (if I can go that deep)
end result decked area would be 4.5m x 1.8m
Thanks in advance,
Matt
Read more: https://www.diynot.com/diy/threads/deck ... z4dHKJ3iu8
dalai
Re: Decking Support Advice Needed for Deck Spanning Gap Between Boundary and Hedge
by dalai » Mon Jun 12, 2017 1:52 pm
check Planning Permission first but to be safe I would have concrete footing at both ends, depends on use. With a span of 1.8m use 2x6 joists with max 24" OC.
It is currently Sun Nov 24, 2024 4:45 pm
