Question about replacing a washer in a bath/mixer tap
col
by col » Tue Aug 21, 2007 12:33 am
I have a bath/shower mixer unit (Helix bath shower/mixer tap), which I had fitted a year ago.
Recently, when the water is diverted to the tap, there is a small leak coming out of the shower head.
It is the type of unit that you push a lever left to divert the water into the sprout (Swan neck) and right when you want to divert water to the shower.
I contacted the company I purchased the unit from and asked their advice and they advised that I should replace the diverter washer, but I cannot see how to access it.
If this is correct to solved the leak, any advice on how to replace the diverter washer would very much appreciated.
It is currently Tue Dec 24, 2024 5:26 am
