Replaceing Ceiling Light With new Fitting With Only 3 Wires
Thenexus
by Thenexus » Wed May 03, 2017 2:06 pm
I am having trouble with the wiring for a ceiling light. I have 4 wires coming out of the ceiling, 2 red and 2 black. These were not attached to any fitting and were taped up.
The fitting I am trying to use has 3 wires yellow, blue and brown. I need to know what goes where?
Thanks for any help.
kbrownie
Re: Replaceing Ceiling Light With new Fitting With Only 3 Wires
by kbrownie » Thu May 04, 2017 10:56 pm
In truth, it would be impossible to inform you of what you have.
What were these cables attached to originally. Your subject says REPLACING, so you most be replacing something.
If cables were not attached to anything, then you need some test equipment to determine what you have. Also no mention of any earth cables??? If there is no earth present, you must not connect class 1 metallic fittings.
by ericmark » Fri May 05, 2017 3:14 pm
I would guess when you say yellow you mean green/yellow, and I would guess one cable goes to switch and one is supply, so likely one wire on each cable connects to a wire on other cable without connecting to lamp.
The problem is we don't know which wire, so some testing is required.
It is currently Sun Jan 12, 2025 2:55 pm
