Fitting Showing Head Bracket Through Tiles and Plasterboard
v-forty
by v-forty » Fri May 12, 2017 1:34 pm
I've just about finished tiling my bathroom, so will be fixing the shower head bracket and shower curtain rail back up in the next few days. Question is, do i need a wall plug for the screws to go into?
My internal wall is made up with:
metal stud frame
12mm plywood screwed to the frame
20mm concrete (waterproof) board screwed to the plywood
tile & adhesive on top of the concrete board, approx 5-6mm thick
I had been looking for long wall plugs, suitable for plasterboard type walls. However, I was advised in a proper-local-type DIY shop that the screws should grip on to the plywood and provide a firm fix for the bracket.
What would people recommend?
It is currently Mon Jan 06, 2025 8:35 pm
