Connecting 3 Core Cable to Ikea Skeninge Power Connector
Emberton
by Emberton » Fri May 19, 2017 10:38 pm
How to connect 3core cable to skeninge power connector?
Re: Connecting 3 Core Cable to Ikea Skeninge Power Connector
by ericmark » Sat May 20, 2017 1:25 pm
http://cdn.ikea.com.tr/montaj-kilavuzu/ ... 316405.pdf pictures from page 11 onwards. Typical Ikea instructions, what it does not say is if they are all three phase or if there is a single phase version, you would need to buy one to find out, likely L1, L2, and L3 need joining together, but instructions are bad.
Emberton
by Emberton » Sat May 20, 2017 10:39 pm
Thanks Eric, I've just found the answer as well on a Greek website??
John
mousepotato
by mousepotato » Sun Sep 10, 2017 4:24 pm
For anyone still puzzled (like me) it becomes clear if you look at the instructions for the individual spots etc. that you can connect to the rail. Each spot has a switch to select between being powered by phase 1-2-3. This way you can have separate wall switches for each phase, and switch different lights on and off independently.
If you only have single phase power, you just wire up one phase in the rail, and switch your spots to use that phase.
3-phase power allows you to have more lighting elements per rail system, and have independent switching.
It is currently Sun Jan 12, 2025 11:37 am
