Waste Pipe Joints Leaking After Rodding to Remove Blockages
pw1976
by pw1976 » Thu Jun 15, 2017 10:05 am
Hi - my kitchen/bathroom waste pipe keeps getting blocked and I need to call dyno rod out once a year to rod them. Last couple of times their vigorous has caused cracks in the joints which then leak through to the downstairs neighbour.
Is there a solution I can put in with stronger joints/pipes? Maybe I can glue them up so they are stronger? Are metal ones available?
Any advice you can give would be appreciated.
It is currently Sat Jan 11, 2025 5:02 pm
