Fitting Double Check Valve When Installing Outside Tap
Gadget
by Gadget » Mon Jun 19, 2017 11:03 pm
Hi Guys,
When fitting an outside tap (HOT), I'm assuming you still need to fit a double check valve? - question is, will there be adequate pressure to open the valve?
I'm guessing this wouldn't be a problem for a pumped combi system? but what about a gravity fed system?
thanks in advance...
kbrownie
Re: Fitting Double Check Valve When Installing Outside Tap
by kbrownie » Sun Jun 25, 2017 11:24 pm
Hot top potable water will not be contaminated.
Gadget
by Gadget » Mon Jun 26, 2017 8:59 am
thanks for reply....
so it's not possible to get the 'syphon effect' on a hot tap? - just trying to understand the difference...
It is currently Mon Dec 30, 2024 8:30 pm
