Plumbing a Radiator and Identifying Feed and Return Pipes
Deebee1
by Deebee1 » Mon Jul 17, 2017 6:35 am
I have recently drained the system to replace all radiators, how can. I tell which is going to be the feed and return pipes now I can turn the combi boiler on
thekeymurphy
Re: Plumbing a Radiator and Identifying Feed and Return Pipes
by thekeymurphy » Tue Jul 18, 2017 3:35 pm
Does the pump have an arrow on it showing directional flow? If not, a bi-directional valve should do the trick. Alternatively, whichever one heats up first is the feed!
Deebee1
by Deebee1 » Tue Jul 18, 2017 8:49 pm
Original post should have said the boiler cannot be turned on as the is no pipes attached etc so cannot feel which pipe gets hot first.
I believe the valves are multi directional these days so hopefully it won't matter when I re attach pies etc
Tall bloke
by Tall bloke » Sat Sep 08, 2018 7:16 pm
It doesn’t matter which is the Heating Flow and Heating return at a radiator as the water will flow through the radiator anyway it can.
It is currently Sat Nov 23, 2024 12:44 am
