Stainless Steel Sink Clips Needed and Silicone Sealing Question
hoogerbooger
by hoogerbooger » Tue Jul 25, 2017 7:48 am
Hope this is the right forum.
Just had my 40mm laminate kitchen worktops replaced. The chippy cut the sink cut-out too tight for the clips, then left for another job. The plumber could only get the clips on one side so put them at the back and used a silicone bead to seal. (The sink being re-inserted had a intact cleaned-up narrow foam seal ).Sink was not weighted while silicone was left to go off and sink was used within a few hours.
Now I'm thinking I've been left with a sink vulnerable to lifting and the seal failing. Is that likely to be the case ? would silicone on it's own be enough ? or are the clips essential ? - I had thought they were - but wasn't there at the time the work was done.
If the silicone seal it is not likely to last - should it be lifted now, cleaned up and the cut-out enlarged at clip locations ? is that a straight forward job ?. I don't want the work top damaged and it may pull off the existing inset seal when removing the silicone ? Seems too late to try just enlarging locally for clips from under with sink in situ, now the silicone has gone off as I may upset the seal.
Advice very welcome - as I have a chippy and plumber I may need to talk to.
It is currently Thu Dec 05, 2024 1:38 am
