How to Wire a Rotary Cam Switch HZ5B 10 Model
6 posts   •   Page 1 of 1
arronston78
by arronston78 » Tue Aug 08, 2017 6:24 pm
Hello. Hope someone can help me? I am trying to wire a rotary cam switch HZ5B 10 model. It's just a simple on / off I need connected to a lamp I am building from scratch. I'm not great with terminology so basic instructions would be great. Thanks in advance.
Re: How to Wire a Rotary Cam Switch HZ5B 10 Model
by Mr White » Tue Aug 08, 2017 9:49 pm
The cam switch you mention is for commercial use, why can you not use an ordinary switch?
What worries me is if it is for commercial use, you should not be connecting it.
arronston78
by arronston78 » Wed Aug 09, 2017 3:10 pm
Mr White wrote:The cam switch you mention is for commercial use, why can you not use an ordinary switch?
Hi. It's for a project. I'm building an industrial look lamp from an old 1950's amp meter. It already has an old cam switch but obviously not safe to use due to age and only need it to be on and off. The switch I'm looking at is for 240v use. I just want to use the original rotary knob but modernise the switch
kbrownie
by kbrownie » Wed Aug 09, 2017 7:01 pm
How does the instructions tell you to wire it up?
by Mr White » Wed Aug 09, 2017 7:59 pm
I would guess it does NOT come with instructions?
I think it would be best if you posted pictures.
arronston78
by arronston78 » Thu Aug 10, 2017 1:44 pm
It dudno come with instructions. But with some help from a mate and a 9v test circuit. I got it going!!
It is currently Sun Nov 24, 2024 2:14 pm
