Stains Appeared on Fresh Exterior Paint Work
tomtom1983
by tomtom1983 » Tue Aug 22, 2017 3:33 pm
Hi all!
I'm hoping you can help!
Outside our house is a small wall and a few years ago I have it a fresh bit of paint!
No problems-all went well.
2 years later I thought I'd best do it again however after this I noticed that it started to stain and then eventually crack.
Not wanting to start a huge job I just went over it again and thought nothing of it.
Again the same thing happened! (Doh!)
So knowing it was a bigger job than just a lick of paint I left it.
This year (about 3 weeks ago) I stripped the wall right back to the brick/sandstone/cement top. Scrubbed it and even did a few repairs to make it a bit smoother!
Then I primed it and eventually painted it with new and better paint.
However....the stains have started to appear again!! Anyone know what it is and how to rectify it? I assume I'll have to take it back to the brick again which I don't really mind if it solves the problem! But obviously would prefer not too!
Have attached a pic of the stains however more pictures can be added if it helps!!
Hope that makes sense!!
Kneesworth
Re: Stains Appeared on Fresh Exterior Paint Work
by Kneesworth » Wed Aug 30, 2017 1:45 pm
I'm presuming that you used a water based paint. The most likely cause of the staining is a greasy or other non water soluble deposit on the surface you painted. You can spray over the staining with a Stainblock (Get in most D.I.Y. shops) or paint over the stains with any oil/solvent based paint, then repaint with the water based.
Hope this solves it,
Kneesworth.
tomtom1983
by tomtom1983 » Wed Aug 30, 2017 7:35 pm
Hi Kneesworth,
Many thanks for your reply!
That's exactly what I have done, I've gone over the water based paint and stains with an oil based paint!
Once the sun comes back again (and it hasn't rained for a few days) I'll give it a brief sanding down and go over it with the water based paint once again! Minimum 2 coats!!
Hopefully that should work. The oil based coat has been on a good few days so far and can't see anything trying to get through yet! Watch this space! Shall let you know!
Thanks again for your response!
Alex
It is currently Fri Nov 22, 2024 6:26 pm
