Fitting new Walk in Cupboard Door Handle With Lock
Zaffy
by Zaffy » Wed Aug 30, 2017 6:08 pm
I have a walk-in cupboard. The door has a handle just on the outside. The handle has a back plate and a lever handle. I want to change the handle to a key lock handle. Is there a handle on the market that I can do a straight swap with? I do not want to chisel out frame and door to fit a new handle.
Doctor DG
Re: Fitting new Walk in Cupboard Door Handle With Lock
by Doctor DG » Mon Oct 02, 2017 6:58 pm
The handle with a keyhole will fit directly in place of the old ones. It'll be longer on the backplate that's all. Handles are available in screwfix or Toolstation as ia the 3 lever mortice lock which you will of course need to fit too.
It is currently Mon Nov 25, 2024 4:59 pm
