Double 2-way Switch Change in Kitchen now Upstairs Lights Don't Work
gingerdog
by gingerdog » Sat Sep 02, 2017 6:59 am
Hi im changing the switch in the kitchen.
Its a double switch
two lights in the kitchen, each switch works a light each.
I've changed the switch the kitchen lights and down stairs work fine, but the lights up stairs upstairs don't work.
So put the old switch back on , turn the mains back on still nothing upstairs.
turn off the mains for 5 mins then back on upstairs is working.
still got the old switch on at the moment.
there are 2 light breakers in the garage,
I guess its something to do with the common.
any pointers would be appreciated
BLAKEY1963
Re: Double 2-way Switch Change in Kitchen now Upstairs Lights Don't Work
by BLAKEY1963 » Mon Sep 04, 2017 12:47 am
gingerdog
You say something to do with the common assuming the upstairs is fed from the switch you changed , then you say the lights come on upstairs after 5 minutes.
I would advise you to ask your local registered electrician.
It is currently Sun Jan 12, 2025 12:01 pm
