Fitting in-line valve
SWEEP
by SWEEP » Fri Aug 24, 2007 8:45 am
Hi, everyone
I want to fit two in-line valves (my description) the type opened and closed using a screw driver into my hot and cold pipes under the kitchen sink so
that I can fit flexible connectors, re-position the sink and fit different taps.
As my propoerty was built in 1960 I assume the pipes are imperial (1/2" size) and not metric and if so presumably I shall need to fit an adaptor and new 15mm pipes to connect from the existing pipework to the in-line valve and then to the taps?
Is there any easy way to check if they are metric or imperial without first cutting the pipes?
Advice gratefully received please.
It is currently Sat Nov 23, 2024 3:18 pm
