Screwing into a Breeze Block Wall for Shelf to Hold Tumble Drier
IanFranks
by IanFranks » Wed Sep 20, 2017 7:56 am
I have to put up a large shelf to hold a tumble drier. It is to go into the corner of a room. However the walls are breeze block and I'm not sure ofthe best way to fix the supporting battens to the walls. Any suggestions welcome.
IanFranks
fidaleo
Re: Screwing into a Breeze Block Wall for Shelf to Hold Tumble Drier
by fidaleo » Mon Jan 25, 2021 12:24 pm
I've used masonry bolts when attaching anything load bearing to breeze block , probably overkill but these go directly in the breeze block and tightened using a socket wrench (not a tool) ...just drill a pilot hole,,,,think it was the 2mm down from the thread of the bolt.
Lightening bolts I think they were called and I used a decent washer to stop it digging into the wood.
https://www.toolstation.com/lightning-m ... olt/p32391
Had great success even in poor quality breeze block
It is currently Thu Nov 21, 2024 7:57 pm
