Wiring to Koller Whirlpool Bath Pump
pothecat
by pothecat » Sat Sep 23, 2017 11:39 am
Hello
I have been given a Whirlpool bath with pump and electrics by Koller. Need to test it to make sure it works before getting the bathroom electrics sorted for it. Have attached a 3 pin plug to the power supply but don't know about connecting the power supply to the pump. The wires were disconnected from the pump when I was given it.
The screw terminal block has 3 open positions on the left for me to choose from but which colour wire do I put in which position?
With many thanks
The electrics box attached to the top of the pump.  White wires go to capacitor that you can just see.  Red and black go into motor casing.  I have already connected the earth as this attaches to the pump body with a screw connection.
This is the pump electrics with the 3 core wire from the power supply box on the bath.  Brown and blue unconnected, yellow/green already connected.
Info on top of pump electrics
Info on power supply.  I have connected the 3 pin plug to the 3 core wire coming from this box
Re: Wiring to Koller Whirlpool Bath Pump
by Mr White » Sat Sep 23, 2017 7:28 pm
Just because its electric sadly does not mean it must be wired "Thus" If you get it wrong there will be a bang, a very big bang, I would suggest you get in touch with the makers of the pump / look on their website for a connection diagram.
BLAKEY1963
by BLAKEY1963 » Sun Sep 24, 2017 11:51 am
pothecat
As Mr white states, a connection diagram is required , to make the correct connections.
Mixing up Polarity ( live and neutral connections ) can be dangerous, and can also damage the item you are attempting to operate.
As always if there is any doubt, you should get in an electrician.
pothecat
by pothecat » Mon Sep 25, 2017 7:23 pm
Thank you both very much for your replies. I will be contacting the manufacturer and asking for the wiring diagram. I have had a good look on the internet but can't find the correct one.
It is currently Fri Nov 22, 2024 1:03 am
