Terrebine Driers for Shortening Paint Drying Time?
Candelle
by Candelle » Wed Sep 27, 2017 10:23 pm
I need to use an oil-based gloss paint on an exterior door.
I understand that I won’t have enough time for a conventional oil-based gloss to dry at this time of the year.
I have read of Terrebine Driers which could shorten the paint’s drying time. Could someone please advise if this product actually works?!
If it does, how much drying time would it save?
Many thanks for any advice.
diydoctor6
Re: Terrebine Driers for Shortening Paint Drying Time?
by diydoctor6 » Mon Oct 30, 2017 3:05 pm
Great question, Candelle.
You are absolutely right that Terrebine Driers can be used to speed up the drying time for paints. They work by speeding up the oxidation process (they attract/adsorb more oxygen so the paint dries much faster).
You will need a paint that uses oxidation in it's drying process - you can find out more about types of paint here:
https://www.diydoctor.org.uk/projects/types-of-paint.htm
The issue with using Terrebine Driers is that they speed up the drying process which can make the paint brittle and overly hard.
They are a very useful trick to have up your sleeve, but use with care.
I'll be interested to see what others say!
It is currently Sun Nov 24, 2024 12:23 am
