Fitting A Replacement Valve In Mains Storage Water Tank
Wind Gatherer
by Wind Gatherer » Thu Oct 05, 2017 7:59 pm
I was wondering how I go about fitting a replacement float valve in my mains water tank?
See attached photos.
Cheers.
diydoctor
Re: Fitting A Replacement Valve In Mains Storage Water Tank
by diydoctor » Mon Oct 09, 2017 12:45 pm
Turn water off at mains. Undo nut connecting valve to water pipe (outside of tank) undo nuts either side of tank wall to free the vale. replace with new ball valve in reverse order. See this page https://www.diydoctor.org.uk/projects/co ... valves.htm
Wind Gatherer
by Wind Gatherer » Wed Oct 11, 2017 9:28 am
diydoctor wrote:Turn water off at mains. Undo nut connecting valve to water pipe (outside of tank) undo nuts either side of tank wall to free the vale. replace with new ball valve in reverse order. See this page https://www.diydoctor.org.uk/projects/co ... valves.htm
OK thank you for replying I'm unemployed and on a very low income and need all the help I can get. I want to get the central heating working before the cold weather kicks in. The inlet pipe to the tank, the big nut on the outside of the tank. Is there going to be a collect underneath that I should wrap PTFE tape around. I don't want to crack the collet retightening the nut.
thedoctor
by thedoctor » Thu Oct 12, 2017 9:42 am
It's a bit hard to say, sometimes there is and sometimes there isn't one, it really depends on who installed it.
If you take your time and take care while doing it, you should be fine
Kind Regards
Wind Gatherer
by Wind Gatherer » Fri Oct 13, 2017 11:31 am
OK.
It is currently Thu Nov 21, 2024 9:31 pm
