Euro Barrel Lock Turning all way Round but not Locking Patio Door?
jimgee4321
by jimgee4321 » Fri Oct 06, 2017 7:41 pm
Have a euro barrel lock on patio door the key turns all the way round but the door will not lock is it the lock or is it the patio door ?
Doctor DG
Re: Euro Barrel Lock Turning all way Round but not Locking Patio Door?
by Doctor DG » Sat Nov 04, 2017 7:01 pm
You will need to remove the euro cylinder in order to eliminate that as the problem. If the euro cylinder is operating outside the door you'll then know that it's a fault in the centre case of the locking mechanism (gearbox) Most gearboxes can be replaced but a few cannot be so an entire new mechanism will be needed.
It is currently Fri Nov 22, 2024 10:07 pm
