I've ordered a wall light to realise it's going to come with a plug instead of needing to be hard wired in.
The lighting set up is weird with 4 wall lights - three controlled by a double switch on the wall and the 4th (the one I want to replace) with a fused switch on the lower part of the wall bellow the light.
This is the instructions for the light I have ordered https://media.made.com/media/assembly/m ... GRY-UK.pdf
Meaning it would just be plugged in and switched on with a switch in the cord.
Does anyone know if it would be possible to wire it in, by removing the switch cord and wiring the hardwires in from the fused switch bellow it?
Thank you, Kirk
