Flood Light Wiring With Red, Yellow and Green Wires
T5erk
by T5erk » Sun Oct 15, 2017 6:57 pm
I have bought an outside sensor flood light, which I want to install. It's just a matter of replacing an old broken one with a new one. I have already done this with a different light, with no issues.
Problem this time is that the new light has red, yellow and green wires instead of the traditional blue, brown and yellow/green.
I don't have any paperwork for the light to explain what is what.
Can anyone help with this?
Re: Flood Light Wiring With Red, Yellow and Green Wires
by Mr White » Sun Oct 15, 2017 9:38 pm
Each manufacturer decides what colour of wire to use for what purpose. The connections should be standard, or at least marked. If they are not then you need to get back in touch with where ever you purchased the light from and ask for the relevant paper work.
sparkie29649
by sparkie29649 » Sun Oct 15, 2017 10:45 pm
If you can post a picture we may be able to help. But with only your description it's only possible to guess.
It is currently Thu Nov 28, 2024 12:37 am
