Water Running Through Outlet Pipe With all Taps Turned off?
Ema1251
by Ema1251 » Tue Oct 17, 2017 12:21 pm
I'd be grateful for any advice please. All taps in the house are turned off with nothing coming through. Water is still trickling through kitchen outlet pipe into the drain so what would need replacing/repairing?
Many thanks
stokeplumber.com
Re: Water Running Through Outlet Pipe With all Taps Turned off?
by stokeplumber.com » Tue Oct 17, 2017 8:45 pm
Check your boiler for any discharge from condensate pipe, the header and main water tank if you have one, it could be an overflow problem. Also toilet overflows etc.
Ema1251
by Ema1251 » Wed Oct 18, 2017 12:01 am
Thank you for taking the time to reply to me. The overflows you mention don't run through this drainpipe. Could it just be a tap washer that needs renewing although no water is running into the sink?
stokeplumber.com
by stokeplumber.com » Wed Oct 18, 2017 10:04 am
If it is just the kitchen drain pipe and nothing is above it, then only anything attached under your sink could cause it to keep running, say a dishwasher or washing machine. You could also have a blockage in the pipe causing the flow of water to slow down in the u bend.
Ema1251
by Ema1251 » Wed Oct 18, 2017 11:32 am
Oh thank you. Hadn't given them a thought - old lady head! Much appreciated x
It is currently Sun Dec 29, 2024 4:11 am
