making an opening to inset an electric fire
PaulD
by PaulD » Sat Aug 25, 2007 9:37 am
Hope someone can help!
I want to put in an inset electric fire where there was previously no opening. The wall is an outside wall of breeze block construction. I probably only need to inset it about 65mm once I've brought the fire forward into line with the mantel and put the back board behind it - so not a deep hole at all. However, should I still be looking to insert a lintel to support this wall above the opening - despite the fact I am not knocking right through?
Afterwards I want to fill the gap between the back board and wall with fire cement and expandable fire proof foam - even though its an electric fire, not gas. Am I being over cautious?
Many thanks to anyone who can advise.
P.
It is currently Fri Jan 03, 2025 5:31 am
