UPVC Drain Holes in Door not Draining Correctly
Ashley260789
by Ashley260789 » Tue Oct 24, 2017 8:57 am
Morning all,
Any help from the experienced would be greatly appreciated.
I installed a new UPVC back door (full glass pane) recently which has two slotted drain holes just below the drip bar. I think I should make it clear at this point that the drain holes are in the door, not the frame.
The problem is that when I open the door into the property the water held in the door comes whooshing out onto the carpet. It appears that the drain holes are not discharging all the water in the door until the centrifugal force from opening the door forces it out.
I hope this explains it clearly and you can help
Regards,
Ashley
JamesDon95
Re: UPVC Drain Holes in Door not Draining Correctly
by JamesDon95 » Mon Dec 04, 2017 3:29 pm
Hi Ashley,
Does this door have a full frame to the bottom and a cill or has it got a low ali threshold?
It is currently Mon Dec 23, 2024 12:26 am
