Wiring for Emeti B2000 Pipe Thermostat
jdmgriffin
by jdmgriffin » Sat Oct 28, 2017 9:56 pm
Hi there. Need to install an emeti b2000 pipe thermostat. That will have a
plug - thermostat - pump as it's setup . Would anyone be able to advise on the wiring. Copy of wiring detail that came with stat and stat itself.
Re: Wiring for Emeti B2000 Pipe Thermostat
by Mr White » Sun Oct 29, 2017 9:26 pm
There seems to be a large thumb in the picture covering some of the text.
jdmgriffin
by jdmgriffin » Mon Oct 30, 2017 10:41 am
Mr White wrote:There seems to be a large thumb in the picture covering some of the text.
Thanks for the reply. The first part is English. 2nd , under thumb, is french...
by ericmark » Mon Oct 30, 2017 2:23 pm
I see nothing in instructions which says a neutral should be connected, it would seem line in P1 and to heater line out 2. The terminal 1 would not be used.
jdmgriffin
by jdmgriffin » Mon Oct 30, 2017 5:52 pm
ericmark wrote:I see nothing in instructions which says a neutral should be connected, it would seem line in P1 and to heater line out 2. The terminal 1 would not be used.
Thanks for that.
There is three therminals on the unit.
P1
1
2
Are you reccommending to connect
Live from plug to p1
And 2 to live of pump ?
I got the nutural connection as the instructions says the common connection ? Is that not a term for nutural?
It is currently Thu Nov 28, 2024 2:00 pm
