Plastering: How should the ply be treated to ensure a good lasting finish?
Terry
by Terry » Thu Mar 22, 2007 8:53 am
I have formed arches ussing 3mm. ply curved around a timber frame in each corner of a cavity wall which was previously knocked through to form an extension.
I am having a skim coat applied over the existing plaster and aws concerned that the plaster may not take to the ply.
Please advise
Terry
by Terry » Thu Mar 22, 2007 8:58 am
Please advise
omulcol
by omulcol » Wed Mar 28, 2007 9:17 pm
[quote="Terry"]I have formed arches ussing 3mm. ply curved around a timber frame in each corner of a cavity wall which was previously knocked through to form an extension.
Please advise[/quote]
There are two ways to tackle this problem.
First, is to staple EML ... or expanded metal lath over the ply and timber, and scratch coat over it using Carlite Bonding - then skim over with MultiFinish.
The second alternative is to apply two coats of neat PVA plastering adhesive over the timber - allowing the first to dry - applying the second coat immediately prior to skimming.
It is currently Thu Nov 21, 2024 10:13 pm
