by Mr White »
Sun Nov 19, 2017 12:47 am
If you want the new light to operate on / off the same time as the existing light then yes connect to the "Live and neutral" But you can only use a double insulated light as there is no earth (There is no earth shown in the picture)
If you want the new light to operate independently of the existing light then you cant as you only have neutral and switched live, you need neutral and permanent live.
