Hello all.
For quite a few months now, the ceiling light in the front lounge has been playing up. The bulb flickers when the dimmer switch is turned and goes completely out after 10-20 seconds.
There are two switches for it as per my amateur diagram attached. One of the switches is a dimmer switch, which when turned does make a slight ‘humming’ sound.
I have changed the bulb to another dimmer suitable one and still the same effect (the bulbs work fine elsewhere in the house).Thus concluding that it might be the dimmer switch itself.
Short of purchasing a new dimmer switch, I thought about looking at the switch itself- safely of course. There seems to be quite a few wires behind the switch as seen in the attached photographs. To be honest I don’t really need a dimmer switch and would be happy with a single one.
Therefore I am seeking help about how to resolve this issue. Is it the dimmer switch? If so how might I go about replacing it and installing the wires correctly. Or might there be a different issue?
I look forward to your responses!
