Correct Layers for Cabin Roof and Should I Also use a Membrane?
Jay Bee
by Jay Bee » Tue Nov 21, 2017 12:43 pm
I'm building a log cabin and I've progressed up to eve height. The roof is next. According to the plan, the layers for the roof, viewed from the inside out are:
1)19mm spruce boards
2) Celotex 50mm foil/foam/foil insulation
3) OSB
4) Bitumen tiles.
I can't help feeling that a membrane or two is missing from the mix. Should I add one and if so, where and what type?
It is currently Thu Jan 09, 2025 1:51 am
