I Need to fix This Manual Tyre Changer to the Ground
Jumanji95
by Jumanji95 » Mon Dec 25, 2017 11:33 pm
I need to put 4 anchor/rawl bolts throught the 4 holes in the base of the tyre changer (see the pic) and fix it to some thick concrete. trouble is I don't have a garage only a grass area and thin paving slabs like in the second pic attached which I think are too thin and will obviously split. Thick concrete only will work I think.
What do I do?
Can I lay a small patch of very thick concrete on the grassy area (immovable when dries hopefully) and then fix the tyre changer to chat with the anchor bolts?
tiles
tiles
tyre changer
tyre changer
Skid Sprocket
Re: I Need to fix This Manual Tyre Changer to the Ground
by Skid Sprocket » Sun Dec 31, 2017 9:44 pm
Jumanji95 wrote:I need to put 4 anchor/rawl bolts throught the 4 holes in the base of the tyre changer (see the pic) and fix it to some thick concrete. trouble is I don't have a garage only a grass area and thin paving slabs like in the second pic attached which I think are too thin and will obviously split. Thick concrete only will work I think.
What do I do?
I would suggest making a full concrete base to cover all 4 holes in one piece. Something you might also want to consider is making the base large enough to allow you to stand on the base while working at the machine.
It is currently Mon Jan 06, 2025 8:41 pm
