New 16amp Cooker on Circuit With 13amp Breaker
Jim123
by Jim123 » Sun Jan 07, 2018 9:59 am
Hi currently looking at replacing cooker, thought it would be simple until I saw that many new cookers are 16 amp rated. I am not an electrician so not sure if I can put one of those in.
At the moment our oven is hard wired in to a cooker switch which also incorporates a 13 amp socket this in turn is protected on the mcb with a 32amp breaker.
Thoughts please. I do have the option of getting a 13 amp rated cooker but wife prefers one of the 16 amp rated ones
Re: New 16amp Cooker on Circuit With 13amp Breaker
by Mr White » Sun Jan 07, 2018 7:57 pm
But you don't use the socket to plug the cooker into, so a 16A cooker will be fine. Most cooker suppliers will connect the new cooker to an existing cooker point for you.
Jim123
by Jim123 » Mon Jan 08, 2018 5:46 pm
I keep getting told that the new cooker should be protected by a 16amp fuse , the only protection it does have is the 32 amp breaker.
having said that i have had a 13amp rated cooker wired in there for past 20 years with no hassle
It is currently Sun Jan 12, 2025 5:40 am
