Removing a Glass Lamp Shade but no Obvious way to Detach From the Ceiling
benpearson83
by benpearson83 » Thu Jan 11, 2018 6:57 pm
I'm having difficulty working out how to remove a glass lampshade from my ceiling. It is screwed to the wall, but I can't work out how I actually unscrew it as there is nowhere obvious to use a screw driver or drill.
Any help would be massively appreciated.
Skid Sprocket
Re: Removing a Glass Lamp Shade but no Obvious way to Detach From the Ceiling
by Skid Sprocket » Sun Jan 14, 2018 11:19 pm
benpearson83 wrote:I'm having difficulty working out how to remove a glass lampshade from my ceiling. It is screwed to the wall, but I can't work out how I actually unscrew it as there is nowhere obvious to use a screw driver or drill.
Photo attached for your ref.
Looking at the photo it looks like the type that is held on by the three dome nuts, these should unscrew with your fingers but be careful to hold the glass as you undo the nuts or it will fall. Hope this helps.
It is currently Fri Nov 15, 2024 12:38 pm
