Kitchen LED's Keep Breaking but are There any Decent Quality ones out There?
8 posts   •   Page 1 of 1
rogersmiththethird
by rogersmiththethird » Mon Jan 15, 2018 2:08 pm
Hi, we've fitted three 3.5W LED downlighters under our kitchen units to illuminate the work tops. But despite claims of 30,000 or 50,000 hour lifespan, they only seem to last for 6 months at most before breaking. The last one I fitted only survived 15 minutes before going dim like the others.
They are mains-powered circular LED units that clip into triangular mounts, like these ones here:
https://www.ebay.co.uk/itm/TRIANGLE-UND ... TB:GB:3160
Any suggestions on better quality replacements or how to extend lifespan? I thought it might be heat but they run pretty cool.
Thanks!
Re: Kitchen LED's Keep Breaking but are There any Decent Quality ones out There?
by Mr White » Mon Jan 15, 2018 8:11 pm
Often the quoted lifespan of an LED lamp it clearly says "up to" xxxx hours, 2 hours is "upto" xxxx hours.
Buy a recognised brand of lamp, not cheap stuff, like wise the fittings make sure they have good solid connections, and like wise if you have a power supply for the lamps use a good well known brand.
Skid Sprocket
by Skid Sprocket » Mon Jan 15, 2018 8:59 pm
I had a look at these LED's and they appear to be dual voltage 110 - 240v. Could it be that the transformers are set to the wrong voltage?
by Mr White » Mon Jan 15, 2018 10:23 pm
LED lamps don't have "Transformers" what you are looking at is the minimum and maximum operating voltage.
If they did have a transformer and it was set to the wrong voltage (too low) they would go bang as soon as they were powered up.
I would still suggest you buy a known brand of lamp. I have quite a few LED lamps here and they are on / off quite a lot must be 3+ years old.
rogersmiththethird
by rogersmiththethird » Tue Jan 16, 2018 8:58 am
Thanks for the replies. Re the lifespan, it's "30,000 Hour lamp life" claimed, not up to. They are failing at 6 months on average so that's way short of their claim.
Re buying a recognised brand that will last longer, do you have any suggestions? That's what my question is really. All the ones on ebay look the same, ie, low quality.
Re transformer settings, these are sealed units with no provision for any adjustment. All 110-240V means is they will work with that range of AC input voltages.
Thanks!
by ericmark » Thu Jan 25, 2018 12:31 am
I have bought home bargains and lidi LED and CFL lamps after the expensive Philips simply did not last, OK Philips CFL not LED but taught me an expensive lesson, cheap ones are better.
I have had some extremely cheap 0.58W 12 volt MR16 replacement LED's fail, but not one of the more expensive types, typical 3 to £10 have failed. 4 LED pods in bedroom now had LED GU10's fitted for over 2 years, the bathroom has 4 x 3W 12 volt lamps well over a year old, kitchen a LED tube around 2 years old, and dinning room 6 x 3W LED candle bulbs and living room 10 x 5W LED globe bulbs non have failed.
There are a few ways to limit the current in LED lamps, the best is considered to be pulse width modulated drivers and with these you often get a voltage range, my drive LED lamp is rated 90 to 250 volt and is clearly a PWM driver in the lamp, as likely is the tube in the kitchen. However these do not dim, so for the typical bulb a very crude capacitor is used to limit current, plus a bleed resistor as without the bleed resistor the lamps will likely glow dim due to capacitive and inductive currents in the supply cables, with 12 volt versions often a resistor is used.
With PWM control we are looking at around 100 lumen per watt, but with resistors and capacitors more like 75 lumen per watt, for caravans and boats with a DC supply you need an expensive lamp rated 10 to 30 volt, and since a fluorescent tube is around 92 lumen per watt with an electronic HF ballast the LED has to be at least 100 lumen per watt to be worth using. However most simple bulbs are between 60 and 80 lumen per watt the larger the wattage the better the lumen per watt as the bleed resistor is what stops it reaching 100 lumen per watt.
So you are very unlucky, in the main the GU10 LED is very good, they do lose some output over time but in general are very good. The problem is as the wattage goes up, the area seems to be reduced, so 3W is about the best size, although you can get 7W unless aimed at a white reflective surface much of the light is lost.
In mothers house I have some 10 and 12 watt ba22d bulbs, but in real terms the light output is not as good as the original 100W tungsten so down stairs I have doubled up on the lamps, and in the bedroom the lighting is really not good enough to read with, but ample for all other things.
At home main bedroom has one 11W CFL and 4 x 3W GU10's two on ceiling and two on the wall either side of the bed.
rogersmiththethird
by rogersmiththethird » Fri Jan 26, 2018 9:10 am
Thanks for the info. In the absence of any better quality recommendations, I'll just keep buying the cheap ones and sending them back for a refund when they break!
by Mr White » Sat Jan 27, 2018 2:03 pm
rogersmiththethird wrote:Thanks for the info. In the absence of any better quality recommendations, I'll just keep buying the cheap ones and sending them back for a refund when they break!
As you wish, but I can't help but think the supplier will will only replace them once. (May be twice) Often written in the small print is something like
"We will replace / exchange the item, and the guarantee will continue for the duration of the original purchase"
So in plain English you buy something with a 12 month guarantee in January, it fails in November, the replacement has a guarantee that will expire at the end of
December (The end of the original guarantee)
I am wondering if the "Decent lamps" are not actually failing due to bad product, but are infact blowing an internal fuse (Something cheap lamps don't have) due to mains spikes, particularly at switch on. Since you have changed the lamps from ? to LED it is likely that the light switches have been "worn" through loading and use, and need internally cleaning, but it is cheaper to buy a new switch than it is to try and do the afore mentioned.
It is currently Wed Jan 29, 2025 12:29 am
