Is Merging two Light Switches a Simple Task?
sheffielddiyguy
by sheffielddiyguy » Thu Jan 25, 2018 10:36 am
Morning chaps, long time browser of this forum. You should all rest safe in the knowledge that your advice has helped me renovate our entire house in the last 8 months. (Just in time for baby no. 1)
So yeah, normally I leave electrics to the electricians but this one seems far too simple to call a sparky in.
I have 2 light switches in my attic room adjacent to each other. The first is a simple 1 way to a ceiling rose. The other is a 2 way to a 2nd switch downstairs that powers a different lamp.
Currently I have to switch on the light at the bottom of the stairs, walk up and then switch on the main light at the separate switch.
My question is this, can I just take the wires from switch one and merge them with switch 2 so both lamps work at the same time? I figure it should be simple but like I said earlier. Electrics make me nervous! haha
Cheers chaps... Really appreciate any advice.
Re: Is Merging two Light Switches a Simple Task?
by Mr White » Thu Jan 25, 2018 8:01 pm
In theory it only needs the switch wire of one switch connecting to the switch wire of the other switch, but it will cause confusion (if it works) later.
I would say no, don't do it.
It is currently Wed Jan 29, 2025 12:46 am
