Trussed Rafters and Studs Spacing for Building Regulations
mirrorek77
by mirrorek77 » Tue Jan 30, 2018 9:37 pm
Dear All,
Does anyone know of any building regulations or recommendations with regards to position of trussed rafters in relation to studs in the stud wall? Common sense would suggest having trusses spaced same as studs in the wall.
We are talking about single storey building with traditional timber construction.
I have used 145mm by 45mm timber for all sole plate, bottom rail, studs, top rail, binder (wall plate).
My understanding of binder/wall plate is to act as roof load transfer onto studs.
Please correct me if I'm wrong.
I went through Trada Timber Frame construction book and NHBC Standards book and couldn’t find anything about this.
Your referenced comment would be much appreciated.
Attached is a picture showing trusses and studs misaligned.
Greetings
Robert
michaelscad
Re: Trussed Rafters and Studs Spacing for Building Regulations
by michaelscad » Wed Jan 31, 2018 1:08 pm
the company that makes them will supply you with all the details including
the calculations needed for the NHBC and the building inspector
It is currently Mon Nov 25, 2024 3:42 am
