Dangerous Gas Pipes in Room in Converted Warehouse Living Space
bswc1988
by bswc1988 » Fri Feb 02, 2018 5:11 pm
Hi there,
I've recently moved into a living space that was converted from a warehouse in North London. I was moving a box around today and smelt gas... realised that I'd accidentally turned this valve on so quickly turned it off! It smelled like natural gas and was coming out quite strongly... it is about an inch a a half thick (the pipe) and says CRANE PN-25 on the side of the pipe. Should this be here and if not should I tell the landlord to sort it out? I get that the pipe may still be there but do not think that it should still be 'live' or hooked up to gas if that makes sense (picture attached). Or is it safe with the valve, does that make it no different to the valve attached to a stove or cooker for instance? Any help would be appreciated as I'm just a bit shocked and confused right now. Thank you!
IloatheBG
Re: Dangerous Gas Pipes in Room in Converted Warehouse Living Space
by IloatheBG » Sat Apr 14, 2018 7:55 pm
That, i beleive, is suitable for natural gas. However, it should never be allowed to be capable of being opened t o atmposphere. It requires a cap to make it safe.
Call 0800 111999 and Cadent will visit to cap off free of charge. they SHOULD then apply the RIDDOR procedure, as it is classed as IMMEDIATELY DANGEROUS (ID), and is a serious contavention of the Gas safety regulations.
there will be no impact on you,but the individual who left it in that state is open to prosecution, although that would be rare, unless an actuall incident arises.
Have you bought the property? If you rent it, there should be a Landlords Gas Safety Certificate, and this should have, argably, been picked up on the inspection. If you do rent, and there is no LLGSC (CP12), he landlord and/or agent is commtting an offence.
Do not ignore it.
Please let us know what happens
It is currently Tue Nov 26, 2024 7:33 am
