Stair Stringer Spreading on Open Tread Stair
rich54
by rich54 » Fri Feb 09, 2018 4:48 pm
Looking for some advise on how to fix spreading stair stringer on an open tread stair.
The treads are just glued in to the stringers and as one side has warped they have slipped out. I've used simple L shaped brackets to relocate each but would like to secure better.
Though I could use some sort of long threaded rods which I could fix to both sides and then tighten in the middle to pull the warped stringer back in.
Can't seem to find anything to do the job other than the sort of wire decking fittings.
Any help would be great.
thanks
It is currently Thu Jan 09, 2025 3:02 pm
