Use of Skylight in Low Head Height Loft Conversion for Building Regs
ivorhooper
by ivorhooper » Tue Feb 13, 2018 1:42 pm
Hello all,
in order to get building regs sign off for a loft conversion, is it permissible to use a skylight in the apex of the roof above the top of the stairs in order to get to the 2m minimum head room height?
Would you then need planning permission?
I've attached an example of the type of skylight that I'm talking about.
thanks
michaelscad
Re: Use of Skylight in Low Head Height Loft Conversion for Building Regs
by michaelscad » Thu Feb 15, 2018 1:30 pm
confusing the issue here, top of stairs isn't a room, planning permissiion depends - is it overlookng neighbours? Is it front or rear?
Thor45
by Thor45 » Wed Mar 28, 2018 9:40 pm
What kind of stairs are you going to use? Maybe think about loft ladder mate.
Twosons53
by Twosons53 » Sat Oct 16, 2021 12:55 pm
I believe you need 2m head height for the stairs, veluxs are often used to gain a small bit extra, if the window is obscure glazed and fixed pane (or over 1.7m from floor level but I doubt you can achieve that.) I'd confirm that by checking the permitted development guidance for householders daily straight forward. An alternative maybe to lower the floor where the new landing for the stair is to achieve 2m then step up into the room? Ask the BCO if they are happy with that?
It is currently Wed Jan 15, 2025 10:20 am
