Window Pushing out and not Shutting Flush When Closed?
karatekid
by karatekid » Wed Feb 21, 2018 1:18 am
Hi guys
One of my Windows seems to not shut flush anymore when closing. As you can see from the photos when I shut the window or push from the inside, at the hinge side (top left) it opens at the bracket slightly and no longer closes flush. As you can see it's worse on the small window. To get it to shut flush you have to push from the outside or pill as you close the window. Unfortunately it's a top floor window.
Any idea why this is happening and how to remedy??
Small window
Small window
Flush
Flush
Closed not flush
Closed not flush
Adler
Re: Window Pushing out and not Shutting Flush When Closed?
by Adler » Fri Feb 23, 2018 12:20 pm
Got same problem on all windows, hinge side pushes out.
On mine there are small plastic sloped pieces in corners and steel pointy wedges that work together to pull it when closing.
In my case its a matter of replacing those plastics as there seem to be no way of adjustment
It is currently Sun Dec 22, 2024 2:01 am
