by sparx »
Tue Aug 28, 2007 9:35 pm
Hi does comply with regs as long as straight line vert. covering not reqd. by regs. or bldg regs. Old rubber cables used to be 'eaten' by lime in plaster so used tube/capping as protection.
If cables go other than vert. or horizontally between points then must either be chased deeper than 50mm. or covered with 'earthed metal', difficult to achieve without using Sheathed/Screened cable types,
regards SPARX
