Electric Gate Flashing Light Not Flashing!
Dleafy
by Dleafy » Mon Mar 05, 2018 2:45 pm
Apparently, the flashing light on our electric gate hasn't been flashing for months now.
I've changed the broken 240v 40w golf ball bulb for a 4W LED golf ball bulb.
The light goes on when the gate opens, but just stays on. It doesn't flash at all.
Could it be because the new bulb is LED????
Thanks in advance.
Dave
Re: Electric Gate Flashing Light Not Flashing!
by Mr White » Mon Mar 05, 2018 7:38 pm
Your question is based upon the assumption that any one who replies is familiar with the equipment you have (Where ever you are) and how it works.
I am sorry to say but I have no idea what equipment you have or where you are, so I can only guess.
It flashed when it had an incandescent load (Your 40w golf ball lamp)
It does not flash with a low wattage LED lamp
Put a 40w golf ball lamp back and see what happens.
If it flashes it means that all is well and that the lamp is fed via a bi-metalic strip flasher unit, which needs a load to work properly. (Similar to what cars used to have to make the indicator lights flash)
Dleafy
by Dleafy » Tue Mar 06, 2018 8:05 am
Thanks, I'll give it a try.
If it doesn't fix the problem, I'll dig out the details of the unit.
Dave
It is currently Sun Jan 12, 2025 2:49 am
